plz help vu+solo2 xbmc problem
Edwin*
i have install 1 codi addon name husham ,and when i start xbmc komt only dhis husham screan and i can not see anithing ,plz help to uninstall this husham and to start xbmc normal ..
crashlog
Enter Go to System/Settings,scroll down to Add-ons press ok,Enabled add-ons press ok,scroll down to video add-ons press ok,scroll down to the add-on you want to un-install and press ok.Highlight uninstall and press ok.Job done.You might want to restart xbmc after that.
i cant see the normal coniguration von xbmc , is another config fom husham , or firetv ,dont no what is this
