Request Polarisation (motorized dish).. a suggestion
Zengari
Hello
Is it possible to change in polarisitain setup that we can put number of the position (like in BP) . If l want to go for example to 23th position l have to go with arrows from 1 to 23. It will be very easy to put manually the numbers... Can it be change with an update please?
thanks in advance
you need to use this feature only once when you're setting up your positioner. Your receiver should move motor automatically when you're changing satellite.
Actually I'm not sure what's wrong with positioner setup menu...
There is nothing wrong with it. If you used BP you will see the diffrence:) Sometimes it was very handy to use it. If not not a big deal dear. Just wondering if it was possible...
