power deep stand by make restart
a7farouk
when i choice power deep standby the vu go to restart and dont stop work
how can fix it or this problem in the image ?
i have due 4k se with obh 4.4 (update online to 4.4.21)
Because there was a problem in that version and it has been discussed in the forum. You need to update it by telnet and then reboot by telnet itself.
It was fixed in 022.
please show me step by step how can i fix it in telnet
There is nothing to fix: you need only to use the usual command by command line, the same p.rodrigues posted above and many other of us have posted many times.
It's useful to follow also other users' posts because many subjects have been discussed many times.
