power loss during flash
frenchtony
Hi I hope someone can help, I was upgrading my vu+ duo2 when the power failed (still crying) Now it boots to a' vu+ your smart linux player' on the tv screen, the box display reads 'double your expectation' and the front white light is on. I have tried a new image on the front usb but no different. if I press the black button above the usb the white light flashes while the button is pressed.
If you are getting through the initial boo then try loading a different image, using a different USB stick, formatted to FAT 32.
Try both the fornt, and rear, USB ports.
Switch off at the rear, insert the USB stick, switch on, at the rear, then hold down the front power button, until it recognizes the USB stick.
you bloody marvel!! I had tried this before but no good. Then I formatted the usb on a windows machine, put it in a rear usb and then pressed the black button in and held it till it recognised the usb and voila!! very grateful cheers
