Never used power line but using belking home network adapters works perfectly.power line should work fine. but don't forget get double home network adapter
I just bought one yesterday, Sitecom homeplug dual pack 500 Mbps to replace my old 54 Mbps WiFi connection to Solo2.
Tested in my apartment on two farthest 230V wall plugs (about 25 m of distance - lenght of power cables inside of walls).
Excellent performance . I can only recommend (also as a replacement of 802.11 n 300 Mbps WiFi).
I have the Duo2, but from what I've seen its wireless is 802.11n, so if Solo2 is like Duo2 you could get up to 150 mb/s connecting to a wifi "n" router.
2.537 MBytes/s (point used as decimal separator)
2.881 MBytes/s
because English people could read 2,537 as 2537 (since comma is used as thousand separator), and 2537 MBytes/s actually evaluate to more than 2 GBytes/s!!!
