Hopefully not a silly question
Using Blackhole 1.4.5, Is there a way to select the preferred audio language track selected?
That saves the prferance for the current session, how do you get the box to always select the preferred language.press Audio @RC>select lang (up/down)@RC....then OK on preferred audio lang!
Have Fun W/BH!
what you mean by " if you save your settings list next time you send it to box you will have all like you adjusted" I'v not understood it at all.Setup all audio tracks (or subtitles) and then restart GUI - now box will remember your settings.
Now if you save your settings list next time you send it to box you will have all like you adjusted.
A preferred language option would be a great addition to BH image
agree i hope a plug-in or the team will do thatWe are now in 1.6.6 (the TS spoke about 1.4.5) and still no solution included for the audio settings. I do not understand why the creators/image bakers refuse to add such a good option.
