Problem after flashed with new image
suriansat
Hi! I flashed my Vu+ Solo2 and after reboot setup begins.
First step: I have to press "OK" (on remote control) when I see the picture in TV, to choose video input HDMI / SCART / RGB.
But I can't go on because nothing happens when I press ok (neither with other buttons), except for the red light on remote control that flashes...
Before flash the remote control worked great and continues working on TV.
I flashed the box with other images (OpenPLI and VIX) but the same thing happens: flash OK and stop at the same step of setup.
Nothing connected at the box except for HDMI cable.
Can u help me? Thanks
Try connecting your receiver using a Scart lead, if possible, and remove the HDMI cable, then see if it works.
If not unplug your receiver, disconnect the LNB cable, or cables, and anything else connected, then try going through the setup options.
If you have an internal hard drive, disconnect it, by removing the cover and disconnecting the cables, after it's unplugged, of course.
You could also try moving the receiver to a different room, just in case there's an external source, interfering with your remote.
You don't need anything connected, to your VU+ Solo 2, including the Co-ax cable, to load an image, or complete the set up, but of course you wont be able to scan in, or view, any channels, at this point.
I disconnected the internal drive and everything (just the A/C adaptor of course) but nothing... even in a different room.
It's hard!
Are you loading the same image, or have you tried different ones?
Have you tried a scart lead, without the HDMI lead being connected?
You could try resetting the remote control, to factory standard. There should be a guide, on the forum, with information on how to do this.
Thanks for your help!
I've tried different images (2 BH, 2 openPLI, 1 vix) and on different usb keys.
I didn't try a scart lead but I tried with no cable connected.
I've resetted the remote control, with 1+6 9-9-6 (reset tv control) and 2+7 help 0-0-0-1 (universal mode/SOLO/DUO).
Done!!!!
I've programmed the remote control, with 2+7 help 0-0-0-2 (it's the code for Vu+ UNO and not with 0-0-0-1 for SOLO).
I don't understand that: before flashing new image the remote control worked fine, now it works with solo's code...
Thanks to all for supporting
