Request Problem connecting to VU+
JmasTM
Hi
I have a problem when I try to connect to my 2 VU+ (Uno abd Uno 4K) with DCC, DCC VU+ and VUCC V08.
Sometimes all works fine, sometimes don't. Yesterday night I can, at this righ moment... I can't!
I leave here a print of the error I get with DCC for an exemple.
Hope somenone helps me.
Thank you
Try this solution, open Dcc_E2 > Expert > Ft Type > uncheck Active for pasive, or viceversa.
I beg your pardon for my poor english.
I've tryed Filezilla and didn't work...
At this moment, I have one box detected by DCC (VU+ Uno) and the second one (VU+ Uno 4K) don't.
Change IP adress on your Vuplus and try to connect with DCC.
And verify that the two Vuplus have note the same IP. Restart your Modem.
No, they have diferent IPs, one with 192.168.1.20 and the other one with 192.168.1.21. The first one detected on DCC, the second one don't.
So, change IP who doesn't connect, instead of 192.168.1.21 choose 192.168.1.28 and thene restart your modem
But you setup netowork in uno4k ?
Maybe you used DHCP and box after reboot look for new ip.
You setup uniqe ip on box and you have good user/passwd.
You setup primary dns ?
