Problem - Create Hard Drive Partition on BH
i use to do it on Vti but now under BH i couldn't find it ... is there any way to do it under PC then use it on vu+?
Yes you can if you have a linux system for ext3 or you have to install a software to do it (I don't know maybe it works with FAT32 too you can try)
