problem dongle wifi netgear wn111 v2 [carl9170]
charasat
i have problem with dongle wifi netgear wn111 v2 dosn't work in blackhole image for vu plus duo and uno and solo .please any one have a solution help me .i have a lot of vu plus and dongle wifi in stock must sell it. thanks...
Your wireless device is an Atheros based device who is not actually supported by BH.
We have planned to support it in near future, depending on our Roadmpa.
(BH 1.7.3) nothing to do ...
shutdown
power off
insert key
power on
nothing in section mount usb
nothing in network
something wrong ..?
thanks in advance..
shutdown
power off
insert key
power on
nothing in network
something wrong ..?
thanks in advance..
I've discovered the mistake. Your device uses driver called carl9170.
I will look into kernel source code if it's avaiable and I will post it here to make some tests.
I hope you can connect to your box via LAN cable ... :)
thanks angelo... :)
This time I manage with a powerline 85 mb ...:cry:
is not exactly the best and I hoping to solve with wifi (wn111 v2) ...fortunately it was a gift ...:)
