Problem dvd player
paperino61
Hi all, in bh 1.42 on my vu+duo integrated dvd player doesn't work.
I tried to install froma addon panel but the answer is something like this:
"can't downgrade version......" or similar
I tried to uninstall and reinstall hot plug extension but every time I try to use "dvd palyer" there is a creash with green screen..
some help please?
bye
g.
some help please?
bye
g.
Solved... by panter12 (thanks). It seems to be a little bug.
To solve uncheck "Disable light skin on azp" in OSD settings and all is ok
bye
g.
