khafanpardaz
i cannot use openvpn i need it
please help me
how i can install it in openBH 1.0?
please help me
remove all the files that you do not need (from your example you only need to keep vpn.conf).ITS EMPTY NO OTHER FILES TO RUN IN THIS SCREEN YOU CAN SEE FILES FOR RUN OPEN VPN you say only config file in this folder need to run open vpn ????
thanks my dearremove all the files that you do not need (from your example you only need to keep vpn.conf).
