Problem installing Black Hole VU+DUO2
himo_it
Problem installing
Black Hole
The problem is that the system was running on the machine and then you installed openpil
Then I decided to go back to Black Hole
But to no avail you have all configured flash disk fat 32
But the device installs the system but did not work please help
First ensure that you have the last updated bootloader, switch off at the rear, switch on again, then read the scrolling message, stating CFE v?, if it's v2 then it's fine.
Try a different USB stick, the cheaper, older, smaller sticks tend to work best.
Finally make sure you have downloaded the correct version, of Blackhole, this is the latest version, for the VU+ Duo2, but you will need to update online, to get to 3.0.3Q:
http://www.vuplus-community.net/board/threads/black-hole-3-0-3-h-kodi-vu-duo2.32202/
When downloaded, unzip, using winzip, winrar, or the free 7-zip.
You should then have a folder called vuplus, this should be sent to your freshly formatted, in FAT 32, USB stick.
Switch off your receiver, using the rocker switch, at the rear of the receiver.
Pull down the flap, front right, and insert your USB stick.
Switch on the receiver, at the rear, and press the power button, nest to the front USB port, on the right hand side, behind the flap.
Leave the receiver while it loads the file, then follow the installation menu, to set everything up.
bootloader CFE v2
Any other image proves that you have installed other copies without problems
problems
installing
Black Hole
bigger problem now
the device no longer shows the word update please click
Power off your DUO2 and don´t forget remove all usb devices attached to your STB ... after that connect the usb device that contains the files for flashing and retry.
