Problem moving between satellites
John Bailey
Hi All
I have a VU+Duo on a motorised (usals) system and using BH image 1.7.3 . I am having problems moving between Satellites.
I should be able to move between satellites using the remote control :-
Channel button- Greenbutton (satellites)-and change satellite, however, this does not work.
The only way I can move between Satellites is :-
Set up- Service searching- Satfinder, this is the only way I can move between Satellites.
Can anyone help please?
Best Regards,
John
Hi All
Best Regards,
John
Verify with care the tuner configuration: I've a USALS rotor and all works correctly using the Simple Setup -> Lat & Long settings setted up and the dish turn correctly ;)
