How do you do such a strange operation? Unless you are talking about the plugin OWIF web tv.
OWIF is not a plugin you can add or update. Instead, if you are trying to install it forcing the use of an .ipk package made by third parties, it's easy to get into errors.
I'd be stick to the embedded plugin you have with the "normal" image.
