Problem rebooting after skin download
Khalidi
Hi All!!!
I wish can find a solution for my issue . After downloading a skin and intsaling it ( I don't remember the name :) ) BH ask me to reboot in order to complete the installation. So once I press OK. My receiver can't startup it shows a green screen.
Will you find in attachment the logs.
Thanks very much
By a FTP software, remove all the folders with a skin name from /us/share/enigma2/ except the skin_default one.
Then restart the GUI.
can change default skin? default skin MX i6P, can i change to MX_SilverLight OBH (Format 1920 x 1080) ?
What for change the skin_default.
Install and use MX_SilverLight OBH ( 1920x1080 ), afaik, you dont´t will have issues with this skin, so you don´t need to overwrite your default skin.
