Problem report: MSI DIGIVOX A/D II
Buha
1. Problem:
Tuner works almost great when connected to Vu+. All channels work except those on CH25 (506 MHz) sometimes wont work. While they wont work on Vu+, it'd work on a PC when i connect it to it with same antenna cable.
2. Tuner:
Make - MSi
Model - DigiVOX A/D II
Interface - USB 2.0 interface
TV Tuner - 75Ohm (UHF/VHF) TV Antenna
Frequency - 51-858MHz tuning range
COFDM - 2K FFT or 8K COFDM demodulator (Fully DVB-T compliant: EST 300-744)
Code Rate - 1/2, 2/3, 3/4, 5/6 and 7/8
BandWidth - 6, 7 or 8MHz
3. /usr/bin/usbtuner -V:
UsbTuner v0.3.12
4. Telnet commands:
in output.txt
1. Problem:
2. Tuner:
Make - MSi
UsbTuner v0.3.12
4. Telnet commands:
in output.txt
After take a look on your debug file, seems all correct without errors.
Seems a bug in the driver
Yeah, i didn't have high expectations as it's an old dongle with analog as welll as digital tuner.
AAfter some testing I have this observations:
1. CH25 channels don't work after reboot of Vu+
2. After watching satellite channels for some time, switching to CH25 terrestrial work
3. I left it on that problematic channel when i went to sleep. other day i went to work without checking, and when i got back, picture was freezed with no signal
IDK if there is anything you can do, as it seems a linux driver issue.
And can you or anybody else answer me a quick question if it's not a problem: Is there any supported DVB-T2 USB tuner?
Thanks for your time, I really appreciate it.
About DVB-T2 support, it's already supported the PCTV 290e BUT PAY ATTENTION if you want to buy it ONLINE because Pinnacle has stopped it's production and now its replaced by PCTV 292e (not yet supported)
