Problem scanning channels
exu7777
Hello!
I bought a new Vu+ SOLO and i'm having problems scanning channels.
If finds 99 channels very fast until 4% and then it doesn't find any more channels untill 100%.
After first scanning, all subsequent scans return 0 channels, and the 99 channels previously scanned can't be viewed.
When the scan stops finding new channels, the last channel it finds (if i remember correctly) is "11771 PID 0x73".
After a reboot, the 99 channels can be viewed and a new scan returns 99 channels again.
Is this a known problem with the tuner on Vu+ SOLO?
Is there a work-around or a fix?
Thank you!
What image U have on!
If not BH try the latest 1.7.5 and Read a little more about how to do installations or upgrading!
May be the XML.file for the Sat's are out of date!
I have tried BH 1.6.7, BH 1.7.4 and Vu+ V7.0. All have this problem.
I'm now back on BH 1.7.4 trying to find a solution.
I have tried to update the /etc/satellites.xml file generating it from http://satellites-xml.eu/ and including all satellites, but i still have the problem.
Is there any useful information on the logs? Which log files should i take a look at?
I will post the satellite/LNB configuration when i get home.
Thank you!
After installing OpenPLi-2.1-beta-vusolo-20120606_usb.zip scanning works! Maybe it's a problem with the DVB driver.
If you need any help fixing this on BH, just ask.
Hi, I'm having this issue on blackhole and would very much like to resolve the issue. Any suggestions?
