Problem setting up 5 lnb
Bragemann
Hello all
I have a VU+ Duo2
I just installed Open Blackhole 01 on the tuner
I have 5 lnb on the following sat 0,8W , 4,9E , 13E , 19E and 28,2 E
I have a DiSEqc with 8 inputs and 1 output
When i config the tuner in simple mode i get signal from the first 4 sat but not from 28,2
I can not figure out how to config in advanced mode to get the right settings
All 5 lnb was working great with blackhole 2,14 whish had the config option AA-AB-BA and so on
can someone help with the complete setup
Thanks in advance
Bragemann
Hej!
Testa detta (try this) "uncommitterd option": (Works for me on VuDuo2-OpenBH)
Configuration Mode: Advanced
Satelitte: Your Choice of sat position
LNB: Lnb 1
Priority: Auto
LOF: Universal Lnb
Voltage Mode: Polarization
Increased Voltage: No
Tone Mode: Band
DiseqC Mode: 1.1
Tone Burst: None
DiseqC 1.0 Command: None
DiseqC 1.1 Command: Input 1
DiseqC 1.1 Repeats: None
Fast DiseqC: No
Sequence Repeat: No
Command Order: Uncommitted, Committed,Toneburst (Not always used)
LNB: Lnb 2
Priority: Auto
LOF: Universal Lnb
Tone Mode: Band
DiseqC Mode: 1.1
Tone Burst: None
DiseqC 1.1 Command: Input 2
Fast DiseqC: No
Sequence Repeat: No
LNB: Lnb 3
Priority: Auto
LOF: Universal Lnb
Tone Mode: Band
DiseqC Mode: 1.1
Tone Burst: None
DiseqC 1.1 Command: Input 3
Fast DiseqC: No
Sequence Repeat: No
LNB: Lnb 4
Priority: Auto
LOF: Universal Lnb
Tone Mode: Band
DiseqC Mode: 1.1
Tone Burst: None
DiseqC 1.1 Command: Input 4
Fast DiseqC: No
Sequence Repeat: No
LNB: Lnb 5
Priority: Auto
LOF: Universal Lnb
Tone Mode: Band
DiseqC Mode: 1.1
Tone Burst: None
DiseqC 1.1 Command: Input 5
Fast DiseqC: No
Sequence Repeat: No
and so on....
____________________________________________________________
Or you could try this... "committed option":
LNB 1:
LNB: Lnb1
Priority: Auto
LOF: Universal Lnb
Tone Mode: Band
DiseqC Mode: 1.1
Tone Burst: None
Committed DiseqC Command: AA
Fast DiseqC: Yes
Sequence Repeat: Yes
Command Order: Committed,Uncommitted,Toneburst
Uncommitted DiseqC Command: Input1
DiseqC Repeats: One
LNB 2:
LNB: Lnb1
Priority: Auto
LOF: Universal Lnb
Tone Mode: Band
DiseqC Mode: 1.1
Tone Burst: None
Committed DiseqC Command: AB
Fast DiseqC: Yes
DiseqC Repeats: One
LNB 3:
LNB: Lnb1
Priority: Auto
LOF: Universal Lnb
Tone Mode: Band
DiseqC Mode: 1.1
Tone Burst: None
Committed DiseqC Command: BA
Fast DiseqC: Yes
DiseqC Repeats: One
LNB 4:
LNB: Lnb1
Priority: Auto
LOF: Universal Lnb
Tone Mode: Band
DiseqC Mode: 1.1
Tone Burst: None
Committed DiseqC Command: BB
Fast DiseqC: Yes
DiseqC Repeats: One
LNB 5:
LNB: Lnb1
Priority: Auto
LOF: Universal Lnb
Tone Mode: Band
DiseqC Mode: 1.1
Tone Burst: None
Fast DiseqC: Yes
DiseqC Repeats: One
Lycka till (Good luck)!
