Problem setting up DVB-C on duo2 - No services!
qwerty123!
Hi all,
I have a problem setting up DVB-C on my new duo2 receiver.
On the tuners setup page all my 4 tuners are set up to DVB-C
As per operator requirements, setup is the following:
Frequence: 450000
Symbolrate: 6875
Modulation: 64
Network ID: 100
All is set up, but the network ID, as I can't find any configuration to put it in, I figure this is my problem.
Tried scanning serveral times with different additional settings on/off like ie. network search.
No luck!.
Firmware version is as attached screenshot - Why experimental ??
Hope anyone can help me out.
Solved the problem!
The old firmware didn't support the new tuners that was inset in the duo2.
Update of the image fixed the problem.
