Hi, shoutcast plugin seems not to be able to download the list of radio. IMHO the problem exixts from some days (next week all worked fine)
Same thing on bh 1.39 and 1.4.2
Connection with internet is ok
some help?
thanks in advance
g.
all was ok .>>But NOW Is NOT OK if you not use my fix.SHOUTcast using new servers.
connection refused 146 >>You must use twice green button for GENRES download instead of once. You must use twice OK button for PLAY instead of once.
about dvdplayer on bh 1.42?>> I have no problems with DVD player inside our image.
All is ok now...thanks a lot
About the question of dvd player ....
Solved... by panter12 (thanks). It seems to be a little bug.
To solve uncheck "Disable light skin on azp" in OSD settings and all is ok (if You check the DVd player crashes"
bye
g.
Do you know if your fix is still working? I tried about a month ago on BH 1.4.4 and it worked, now I tried on BH 1.4.5 but it can't load any generes (pushing twice the green button)
