Problem Tdt Mygica t230c
abazu
Hello I have a problem with the Tdt Mygica t230c, I have the Vu + one 4K SE decoder and the Black Hole 3.0.9.C image the decoder does not recognize me the tdt you know any solution or if you have to install a driver thank you very much
New Mygica T230C, ID 0572:c68a ??
Si es la nueva version ID 0572:c68a, los driver del modelo viejo no la reconocen.
En este post prepararon un parche, pero no esta añadida a la siguiente version, le toco meter de nuevo a mano.
Solucion en el post 13
If it is the new version ID 0572: c68a, the drivers of the old model do not recognize it.
In this thread they prepared a patch, but it is not added to the next version, I have to put it again by hand.
Solution in post 13
====> http://www.vuplus-community.net/board/threads/mygica-mini-dvb-t2-usb-stick-t230c.38427/
