problem to mount USB as hdd with Black Hole image 3.0.8.C installed IN OMB
amartag
Good evening everyone . i have a problem of my USB mount as hdd with my image Black Hole image 3.0.8.C installed IN OMB (OpenMultiboot). openatv internal image 6.3. reciver zero 4k.
Usb always go up as omb. And when I mount it as hdd and I restart the reciver
image hangs on boot. please help me
Wich image have you in Flash?
nunigia
Why U using a 16 G USB as HD, and is it clean/formatted or it has other files, images,,,, on it?
If you have OMB installed on the same USB Memorystick its for your own protection you cant mount it as HDD :)
If you where to do that OMB would lose track of its location and box would chrash ;)
So only solution is to change the search path for recordings to OMB not HDD
yes, a good solution. but I can not find the OMB folder in paths to save to change the search path of the records. OMB not HDD
