Problem to setup rotor
vdurieu
Hello
I have this config :
vu+ duo
black hole 1.7.2
settings vhannibal rotor
flat antena selfsat with rotor diseqc 1.2 selfsat HH90
I would like to switch automatically from astra 19.2E to hotbird 13E when I change channel.
Now I have to do it manually using this procedure :
1) switch tuner to USALS
setup - service searching
tuner config - tuner A
configuration mode : simple
mode : positionner
longitude : 004.352 east
latitude : 050.860 north
remark : its my position in google maps (belgium-brussels)
2) goto the stored position for e.a hotbird
positionner setup
tune :
tune : predifined transponder
satellite : 20 hotbird 13.0E
transponder : 10719000, 27500000,V, FEC 5/6
positionner storage : 1 > goto
ps : hotbird stored previously using positionner movement then positionner storage (store)
3) switch tuner to hotbird
mode : single
satellite : 20 hotbird 13E or 22 astra 19.2E
send diseqc : yes
done.
If I let the tuner in USALS after step 2
and I select one astra channel, the rotor turns (don't know where), and the blinking satellite icon remains on screen, even after the rotor stops
how can I do to switch auto between both sats : goto right sat position depending on the channel selected ?
any help apreciated.
Your rotor is USALS compatible.
You must configure your rotor Simple -> Positioner. Issue your LAT/LONG position and nothing more
With your rotor settings installed, change channel and the dish will move.
Tested with same rotor with various Vu+ boxes and BH images.
Satellite store position are NOT used if you have an USALS rotor.
