Problem twin tuner and PIP
semch
Hello,
I installed the image Black Hole 2.0.6 on my vu + duo2.
The concern is the twin tuner, I can not do PIP :/
My config:
Tuner A: single Astra
Tuner B: looped by A
With MEOBOOT and with the same tuner config it works fine for VTI and OpenATV images ...
So I really do not understand why it does not work on Black Hole: (
Do you have any idea?
Thank you for your help.
Hello,
My config:
If you've only got a single feed looped I think you can only watch channels on same transponder.
Hello,
My config:
Tuner A single Astra
Tuner B loopthrough to Tuner A
You can watch all channels on Astra with the same polarisation .
BH image Of course as a flash image .
But channels must also lie within the same local oscillator frequency range (low band or high band) as selected by the 22 kHz signal.
thank you for the answer. this is my tuner's configuration but it does not work ...
I don't understand why
I found : there is channel OK and other not OK
I d'ont understand why because all of this channel are the same polarisation
