Problem using remote stream converter vu+ solo2.
osdieman
Hi to all..
I have a question related to my vu+ solo2 and remote stream converter.
In my living room i have a Solo2 box running at this moment black hole 2.1.7
everything i need ins fine on the box..
now i also use an old dm 800hd in my bedroom but without a tuner ( no sat can be connected there ).
i have two problems here. the first is when my solo2 runs any black hole image the dm will not get epg info from the solo2.. when i run the solo2 on Openpli this works fine and the dm acts like it has a full tuner installed..
Second problem.. while watching tv on my dm ( using remote stream channels ) i have manny stutters and short glitches.. this problem i don't have when i use a dm800hd as main box as well..
the network is fully cabled.. so it can't be that is a problem ..( also why would the setup DM to DM not have this problem.)
So i am thinking there must be something wrong with the ethernet drivers for my solo2.. it looks like it is loosing some packets underway.. my knowledge is not that good to invest this myself.. is here someone who is willing and able to help me with this problem..
Old setup : bedroom DM800 ==> remote stream converter channels ==> to living room DM800 no prob.
New setup : bedroom DM800 ==> remote stream converter channels ==> to living room solo2 stutter.
epg info on DM800 when using Black Hole image on solo2 <== NO
epg info on DM800 when using OpenPli on solo2 <== YES
