problem with 1.7.5
cozmo
as the title say i have come across a problem with 1.7.5 when i install the image on my duo from fresh to flash all seams to work ok then i setup the wizard and then go on bh server and download cateyes latest channel list again all seams fine but if i goto bbc hd or bbc one hd box crashes to green screen every time. that's no plugin no skins nothing just load channel list and bang on them channels green screen box reboots so i went back to 1.7.4 did the same thing as above and all good no green screen when on them channels i have now tried this a number of time and always get same problem so im guessing its a bug somewhere in 1.7.5 as nothing else has changed from 1.7.4 witch runs great
here is a crash log if its helps you i have renamed .log to .txt so i could upload the file
thanks
Cozmo
Well , about this I have already writte
not a bug in the image but in Settings
The same image works without green screen with other settings .
I have test with @Likra
DreamBoxEdit report errors in cateyes.
I have had the same problem as described above. BUT I also got the green screen when on 23 degrees. It appeared linked to viewing HD channels. Again I used cats eye settings. I downgraded to 1.7.4 and installed cats eye settings again.
It's running ok with this
Maybe a rescan is required on other sats ?
Sent from my iPhone using Tapatalk ..... Whist proclaiming the machine fixed, grabbing the cash and running like hell.
I had the problem on 28e, 13e and 9e so I rescanned the lot, my settings are based on catseye's
