outside2000
I was flipping through channels on Sky UK and I noticed that channels on the 12382 H transponder would have a fluctuation of 10% on the SNR bar. At first I thought it was either a problem with the LNB or the cable. So I went on the roof and changed the LNB but the issue persisted. I also have a regular Solo receiver and a card on my PC, so I tried the cables feeding them, and yet again no change. It happens on both tuners of the Solo2. When I tried reproducing the problem on the Solo or the PC card, when I'd flip back to the channels of the transponder-in-question, I'd get the same high SNR every single time, no fluctuation. I even interchanged all 4 cables on every receiver and the Solo and the PC card would always give me the high SNR, no matter how many times I flipped back to a channel on that frequency. So I'm thinking: I eliminated the possibility of a faulty LNB or problematic cabling. My next thought was to try reverting to an older Blackhole (I was on 2.0.4 when I noticed the problem, so I tried going back to 2.0.3), but the issue persisted on both tuners. Most flip backs come in strong, but a couple of them come in with 10-11% decreased SNR. I even tried a couple of different iterations of the drivers, rebooted, and once more same issue. What puzzles me is that I haven't noticed it on any other channels/transponders, so if the tuners were to blame, would they only be glitchy on that particular frequency? Then again, I can't for the life of me reproduce the issue on the Solo or my PC, no matter how many times I've flipped back to a channel on that transponder, and with all 4 feed-in cables tried out, so ?!?!?!? Should I RMA the box or is there something else I'm missing?
