Problem with a plugin
MiroHD
Hello Guys ,
soo i've installed the newest blackhole and everything looks fine and i have also installed a plugin called TSMedia and its all fine .... now when i try to install the plugin called IPTV List updater using the Telnet or using VUCC it gives me this error
cannot specify the following dependancy : **udpxy**
i've searced google for this and it turns out that i should have a file called udpxy in a folder in my vu duo i've did everything as said in the tutorial but still when i try to install the plugin i get the same problem
My Box : Vu Duo
My Black Hole : http://www.vuplus-community.net/board/threads/black-hole-vu-duo-2-1-7.23850/
Thanks in advance guys and i hope that somebody can help :)​
