Problem with AF9015 based stick in latest BH 2.1.4
jeppese55
Hi! Sorry for beeing a complete newbie, but is there anyone outthere who has a solution how to get a Af9015-based DVB stick to work with BH 2.1.4 installed in a new Solo SE? I found a driver for the 9015 via TS Panel but it doesn't install, some error message about the kernel in BH. Is this a known issue? Same stick worked with Open Pli 4 and D800 SE. Appreciate all hints, tips etc
Additional info: The stick seems to be found if I check tuner config, but it says "dummy, not supported". Missing driver(-s)?
TS Pane not welcome in this Board.
Drivers for your device are been included by default in BH image and reading your logs, the device is correctly detected and mapped as DVB-T device.
Ok, I see. But why is it detected (which is somehow ok) as "dummy" device in the tuner config page? Should i perform a new, clean setup and install the stick again? In what order do You suggest that I install the stick? After a clean setup and some basic configuration of the box or can I have the stick inserted when I start the new installation (i.e. booting new F/W)?? Thanks for your support and patience......
Stick must be connected to STB before boot. If it will be connected during boot phase, the device will be detected as "dummy".
Thanks for quick respons!
I'll try and re-install/flash F/W again and do accordingly!
Merry Christmas to all You lucky VU owners/users !!
