Problem with BH or skin?
ivimail
Hi, I have installed BH 2.0.9 and I see in some menus of the system that text doesn't appear complete or text from 2 or more fields are underhand each other. For example, when I search satellites I can see the text of current sat and nº of scanned channels clearly on Hellas Sat 2, but when I scan Astra 19,2 I can't see all the text because the "real name" of the sat is Astra 1KR/1L/1M/2C (too long for that field). My question is that if it's a problem of the design in BH or the skin? I don't understand why if you have a wide screen the info screen can't be a little more wide in order to accomodate all the text correctly
Of course nothing is perfect.
Skin is made with the English language
If you're using a different language , that is the problem of translation.
(to long)
SAT scan the same problem it is because the SAT list You use has long names .
I have only 19.2E Astra 01
The problem is that those who are doing something for the images
(translation,SAT list,addons e.t.c)
do not take into account that text should be as short as possible.
Earlier it was even worse .
Why write the whole story
If enough 19.2E Astra1
So everything is a compromise...
I understand that basically the problem is on the skin design, so if I try with another skin the problem could dissapear, isn't it? Relly is not a big issue, it's more aesthetical than funcional problem, but if I could solve it...
