Problem with bouquets (IPTV)
Marti99
I got a Vu+ Zero with IPTV.
The information is located in userbouquet.Example__tv_.tv
I can't use Dreamboxedit to make bouquets and use marker. I can choose channels but it will not work, no sound or picture. Choosing the same channel in the original bouquet made when IPTV was installed works.
I can reduce text lines in the file. But if try to create something it doesn't load.
We're two users with the same problem with Vu+ Zero (
Black Hole 3.0.9.F Vu+ Zero & Vu+ Zero Rev.2.0) through USB and online updated packages.
and Vu+ Duo 2 is loaded with 3.09i just through online update.
We are not using any plugin for IPTV.
We have the same provider.
Any advice?
