Problem with Dual Tuner of VU+ Solo SE V2
rainkinges
Hello there,
The image BH 3.0.2 F that I am using works as a charm. I am having some issues with the Dual Tuner of my VU+ Solo SE V2. I have a LNB Monoblock pointing to Hotbird and Astra. I have configured the tuners as A Diseq A/B, Hotbird, Astra, and the two following options as yes. The tuner B connected to A. When I try to PIP the small window is showing great, but the big one is blank, even if it is from the same satellite. Any clue what I am doing wrong?
Also, when watching a film in KODI, the image is distort. Is there any way to change the aspect ratio? Any way to change the player?
Cheers.
Hey,
on my configuration i have the tunner B disabled and it works perfectly. can you try to do the same and test?
Regards
