problem with EPG after reboot
lefjomp
hi!
im using the built in EPG software in the latest BH image, it works very well and i get a good epg out of it, the only problem i have is when i reboot or restart enigma, i loose the epg.
i have set the epg software to download the epg every night, so in the morning the epg is back again.
so is there any way to get the epg to show after a reboot or restart of enigma?
hope you understand.
hi!
Have you checked if every time your make reboot/restart your USB is mounted ??
If not then you have to look for USB stick which working better with your box.
Or you can try to use USB stick mounted but formated in FAT32 only (i have not test this but i think is possible to use FAT32)
I am getting the same. My path is /media/hdd. The cross epg download is crashing too. Both have only started since Sunday. I am also on the latest image.
you really should save your epg data to usb /media/usb crossepg recommends not saving to internal flash, it will quickly fill and box will have problems. If you haven't both tuners connected, you may have trouble with crossepg, you must set tuner b to loop thru tuner a, also check you have a provider for crossepg
selected and saved for it to download from
It is saved to a internal hard drive, not internal flash. This the first time I have had issues over 5 different version builds. My son's box is still on the previous version (also built by me) and it has no issues with epg and/or cross epg.
Hello,
I have the same problem. On the built in epg, the file epg.dat is not exist. I have epg for all the channels but after reboot or restart GUI, the epg disappear. Black Hole version: 2.0.8.1
Thanks
it may also be the epg data file on the hdd has become corrupt, try deleting it and then download again
