Problem with IPTV
tex63willer
Hallo to everybody. I have a Vu + Ultimo4k with Black Hole 3.0.9. After instllling the IPTV string with putty, everything works fine. At the first reboot the IPTV bouquet is n/a and there is no way to install it again. The message error of wget is: bad address. I tried to put this string in the IPTV.sh file (while ! ping -c 1 google.it &>/dev/null; do sleep 1; done) but didn't work (i foud this solution in other tread). The only way to solve is to flash again the image and do everything again.....
Thank for every help!
I had a similar problem using OpenPli image .. updating the image solved THAT problem ...
However the new image caused OTHER problems ..:furious:
btw .. don't you use Xtreme Editor ?
If you have problem using PLI images PLEASE ask in PLI Forum because in this forum we discuss and assist Blach Hole and Open Black Hole images only.
Many thanks.
Script files are sometimes a mess and personal i dont like them because they are really unsafe.
When you run a script file it can install, modify or in worst case accully break your box with bad coding.
Rather use one of all the plugins designed to create bouquets for you where you have control
over what you are doing.
My personal favorit is Jedi but there others like suls E2m3u2bouquet
last name i think can be found in the plugin feed of both BH and OBH image
so are really safe to use.
Jedi for BH and OBH can be found here. latest version is in last post.
https://www.vuplus-community.net/board/threads/jedimakerxtream-iptv-bouquet-plugin.38939/
Usually "bad address" in conjunction with wget utility mean that the URL you try to download is not valid anymore and the box cannot resolve the server name where the IPTV list should be downloaded by your box.
Thath's true, but if i flash again the image the same address works....
How does the script create your Favorites?
Is it with one folder named "IPTV" or do you get all countries as single folders "UK somehting"
Hi all,
I have a simular problem. I have a vu+ solo 4K, blackhole 9 and jedimaker. Also I have installed de service app and the ext3player.
If I make a playlist from the m3u file it does not play any channel. If I use the same m3u file in the vlc player in windows it plays every channel.
What am I doing wrong? What do I do to play on blackhole?
There was a small bug with Blackhole image if the country code was first in the channel name e.g UK: BBC News
For some reason BH did not like this but latest Jedi takes care of this issue so all should work just fine now :)
And nice that you have it all working :)
