Problem with IRDERTO cards
helios
After the last driver update i have seen that the receiver is having problems reading irderto cards
have 2 original cards 1 MTV unlimited and a Bulsat also , after every reboot the MTV card is reading it write away , for the irderto card the receiver is able to read it after 10 to 60 min , think that it was a problem with the very first drivers and after that the problem was solved .
So please if there is any solution would love to here it .
Regards
Regards
What CI CAM Module do you use actually?
I know and reading to other peers, vu + have problems with their readers and this type of cards.
is more problem than the actual reader itself *******
is a review to see if someone confirms it.
as i wrote above
"i think that it was a problem with the very first drivers and after that the problem was solved"
and i am positive about that because always use irderto cards
a am talking about the internal readers and i have try ***** (all versions) , ***** , *****-***** , ***** -mgcam with no luck , but after 10-60 minutes the readers start to work
Ok.
This thread will be closed HERE.
Please read rules of this board.
