Problem with latest Makefile from VU+
komodo
Hi,
i'm trying to build latest VU+ for Solo2.
First problem was with fakeroot package, i must download this package from snapshots debian repo.
But now i got always this error
ERROR: function do_compile failed
ERROR: see log in /home/komodo/data/VU+/Build/vusolo2/build/tmp/work/mipsel-oe-linux/libx11-1_1.3.3-r6/temp/log.do_compile.15265
NOTE: Task failed: /home/komodo/data/VU+/Build/vusolo2/build/tmp/work/mipsel-oe-linux/libx11-1_1.3.3-r6/temp/log.do_compile.15265
ERROR: TaskFailed event exception, aborting
ERROR: Build of /home/komodo/data/VU+/Build/vusolo2/openembedded/recipes/xorg-lib/libx11_1.3.3.bb do_compile failed
ERROR: Task 823 (/home/komodo/data/VU+/Build/vusolo2/openembedded/recipes/xorg-lib/libx11_1.3.3.bb, do_compile) failed
and in the log is this
/usr/bin/groff -Tps -e -t -ms -dxV="libX11 1.3.3" -I. ../../specs/macros.t libX11.ms 2> index.libX11.ps.raw > libX11.ps
  table wider than line width
make[2]: *** [libX11.ps] Error 1
I found that this problem is caused by new version of groff.
I try to make groff from OE but it seems that system installed grof is always used.
How could i resolve this ?
P.S. There are quite old packages IMO.
Thank you
Martin
Ok,
downgrading groff from 1.21-9 to 1.20.1-10, solved this problem.
But i am not happy doing such changes to my system :-)
Martin
Ok, done :)
Here is what do i ned to change to build the image on Debian Testing.
1. asi i wrote, i need to manually download fakeroot package and put it in to source dir.
http://snapshot.debian.org/archive/...Z/pool/main/f/fakeroot/fakeroot_1.12.4.tar.gz
2. downgrade groff to 1.20.1-10
3. add recipe file for dosfstools_3.0.14.bb
4. download manually base-passwd_3.5.20.tar.gz
So i hope this may help someone.
P.S. I t will be good to try build all packages on recet linux distros and fix those problems.
Tnanks
Martin
