Problem with lcd4linux
hall9000
Hi
I have installed image on Vuplus duo due , all was ok, i have installed some addons, but at the same moment i saw the display turned out to be black.
I looked the list of addons and there wasn't lcd4linux
I reinstalled the addons and the display now is always on screen color Vuduo2
What did i do wrong?
I dont want to reflash my Vu another time.
Thanks ;)
Hall
Hi
Thanks ;)
Hall
What image have you installed in your STB?
Hi nunigaia :)
The image is 3.0.1 F
The 1st time happened this i had also installed your config about lcd4linux and all was ok
After i remember i installed some addons ( casacinema, portale hd and many others..) and the display become black but i didnt realized whats happened... only after i watched to the display ...
I reflashed....
The second time i didnt touched config about lcd4linux but after installation about the addons i realized that happened 4 the second time...
Tomorrow i want to reflash all and i want to make a good backup...
Thanks for your help
Hall
P.s. Sorry 4 my english :(
Hi nunigaia :)
I reflashed....
Hall
Check Lcd4Linux plugin in plugins list browser.
Enable there Lcd4Linux ... save it ... and restart your STB.
Hi
I do it and on the windows tell me that some are not disponible
I cant see lcd4linux in Blackhole green panel
But i can find it in delete list
Strange... :cry:
How i can enable Lcd4Linux?
Thanks :thanks:
Hall
Hi
Strange... :cry:
Thanks :thanks:
Hall
1) - Uninstall lcd4linux first.
2) - restart enigma2
3) - reinstall it from plugins extensions.
reboot
acess plugins browser ... and see what´s happen ... reply if you can see now on plugins list - LCD4Linux
Hi
I do it
And also i deleted the folder lcd4linux via Ftp
Reinstalled it but like you can see on the screen dont run...
And i cant find it on the BH green panel :(
Thats all :wallbash:
Hall ;)
