Problem with playback recorded video
platiniboy
Hello.
I have trouble with playing recorded videos on Vu Solo 4k
After scrolling forwards or backwards and then clicking play - the sound goes, but the picture frezee.
‏I used internal HDD and USB powered external hard drives (Western Digital My Book USB 3.0) but I almost faced freeze problem in screen while forwarding and backwarding a reced video from a Full HD channel
And I use the remote control of receiver solo4k for forwarding and backwarding and I use >> keys
Hello.
And I use the remote control of receiver solo4k for forwarding and backwarding and I use >> ****
http://www.yourfilelink.com/get.php?fid=1372742
What skin is that, in the video, and what image are you using?
This forum is mostly for Blackhole, and Open Blackhole.
Is this a clean installation, of the latest Blackhole image, without using any of your backups?
I have never had this problem, on my VU+ Duo2, but I have an internal hard drive, formatted years ago, using the Blackhole image.
Try removing any hard drive, recording device, fit a different hard drive, do a clean installation, of the latest Blackhole image, then format the hard drive, and record some programs, to see if it then works normally.
I had the same problem with the solo4K and internal hdd and with all the images that i tried from OpenPli etc etc till Blackhole!!! Now with my ultimo4K never had this problem with the same hdd 1TB drive.
In your opinion, why solo4k has this problem but ultimo4k doesn't?
