Problem with SCR output in Vu + DUO 4K SE
VinseX
Hi, someone can tell me why I changed the cable by putting it in the SCR socket of my LNB with Open BlackHole 4.4 image and I see fewer channels, the HDs of Mediaset and RAI disappeared.
Tuner A Settings:
Satellite: 13.0E Hotbird 13B / 13C / 13E
LNB: LNB 1
Priority: Auto
LNB type: SCR (Unicable / JESS)
SCR (Unicable / JESS) type: SCR (Unicable / JESS) LNB
Builder: Humax
Model: 150 CR
Channel: User Band 1 (1210)
Connected: No
DiSeqC mode: None
Force legacy signal statistics: no
Tuner B: Disabled
Thanks for the attention.
Sorry I solved.
My question is another but do I have to configure tuner B the same as tuner A?
To be able to see the channels while recording with tuner A?
With a unicable LNB I think you have numerous tuners, A-G, to allow you to record, and view, several channels, or connect more sat receivers.
I think you need to configure your tuner setup, but check other threads, on the forum, as I don't have a unicable LNB.
Are you running Black Hole, or Open Black Hole?
