Problem with sound going on/off with Black Hole 1.7.2?
Jonathan
Hi all,
I installed Black Hole 1.7.2 yesterday and am experiencing problems with the sound.
When I change channel, SOMETIMES the sound is gone. Need to change channel several times or restart box to get it working again. Really annoying. No speciflc channel (random problem)
Using Media player: the sound is gone for a couple of seconds then plays for 30 seconds, then goes off and so on.
Used Black Hole 1.6.6. before without problems.
Box is VU+ Duo.
Upgraded existing configuration (not fresh install).
One more problem: I need to manually start the ****** when I switch between Canal+ and Viasat (swedish chalnnels). It's set as default and is the only cams installed except for common interface.
I guess the question is: Should I reinstall .7.2 or go back to 1.6.6? Or are there any other tricks I should try out?
ok, sorry about that. Ignore the last part (should have deleted the last part if I just found any 'edit' button).
i switched from bbc1 wales to ITV HD and lost sound, i then changed channel cound came back on then i went back to itv hd and the sound was also back.
hope this helps
p.s i have a belkin usb dongle and blackhole is not picking this up? any ideas
hope this helps
Have you make a new scan of your 28.2E Sat or have you installed updated settings?
I have problems with the sound when i streaming movies from a NAS.
First 3 a 4 minutes its oke but after that sound comes and goes af ter few seconds.
I have this with all my movies, there is no problemen with streamen on a pc.
