External USB Problem with the recording on the external hard drive
lvloha
Hello,
I had a problem with the recording on the external hard drive (Vu+ Zero)
the adjustment of the device is correct. Timeshift works well, but if I start recording, the new file is created. but I can not see the media player, if I import the * .ts file on my PC, I can see it.
with Version 2.1.7, recording works well, but there are other bugs. with all versions 3.X.X still I find this problem
Does someone has the same problem, a solution ??
Hello,
You have to set mediaplayer by press the <menu> key and apply to the settings /media/hdd/movie ... you should see thow your recordings to play it locally.
@nunigaia, thank you for your reply, but if you read my post, I said that with version 2.1.7, the record is correct, so I know how to do it (by the press <menu> key and apply to the settings / media / hdd / movie) and this is not my problem, the recorded file is present in the media player list, but when I try to read (with mediaplayer) black screen, no information or messages error.
for more information, I did a test, I made a record with 2.1.7, I uploaded to version 3.0.2, I did not initialize the hard disk. with the media player I accessed the file (by the Press <menu> key and apply the settings to / media / hdd / movie) and I could play the recording.
is that nobody has this problem?
Munigaia, thank you for your reply, but if you read my post, I said that with version 2.1.7, the record is correct, so I know how to do it (by the press <menu> key and apply to the settings / media / hdd / movie) and this is not my problem, the recorded file is present in the media player list, but when I try to read (with mediaplayer) black screen, no information or messages error.
Did you have your ( storage device ) mapped?
With the exeption of the test I did, always, to install a new image (3.0.2 C, D, E) I make an initialisation of external storage. but still the same problem to record
But the pause (timeshift) works well.
Can you go to BlackHole App's Menu > Devices Manager and make a screenshot of your connected devices. You can do the screenshot with openwebif. Upload it here. Thank you
by chance I detected the problem. with older versions, simply select the file in the Fileliste left and click on play and play starts, with version 3, if the playlist contains media, you have to go to the Playlist first, then select and play.
from the fileliste, you will have a black screen.
thank you for your help
