Problem with the response of the remote control after install BH 2.1.5
xpertino
Hi,
I installed recently BH 2.1.5, every think work fine just the problem with the response of the remote control. it doesnt work to press the same button twice. Then i installed BH 2.1.0, the problem continue.
It's not battery problem since i changed it and problem still exists. Anyone else have the same problem ?
Hi,
Try getting close to your STB ... and verify if the problem continues! Check too, the batteries, try another set of them!
Best regards
