problem with timezone
gilad2211
hallo.
i have vu+ solo 4k with blackhole image version h.
i'm from israel.
when i put jerusalem time it's show me wrong time. it's 1 hour later then the real time.
there is a fix for that? maybe plugin with net sync option?
it's importent beacuse the epg and rec and not sync.
thx.
Hi,
I have a similar problem.
I have the newest version Black Hole 3.0.4.C Vu+ SoloSE - the time is set by the transpoder and whichever timezone i select does not change.
It seems like the timezone setting does not work at all.
Any ideas of how to make the timezone work?
