problem with TP-Link router and BH 2.0.7
acer2
Hi,
I have TP-Link, model TL-WR941ND router, It worked ok, but until las images, I have problem. I can't online update Image. Internet is OK. I could download plugins from panel-noproblem. But,if I try to online update, always got on scrren : your network does not work. Please,try again.
If I test my network, all is OK, but IP adress is unconfirme (red). Here is my wifi.txt. I hope you can help me
regards
acer2
Hi,
regards
acer2
Seems all OK.
The ip address has to be confirmed in green instead of red or you will have problems. Try removing the AC power for the router for about 30 seconds as a reset, Then reboot the receiver.
Thanks all,
angelofsky1980 wrote-:
Seems all ok- why does nott work, and I could not download online BH update?
el bandido , jes I know must be in green confirmed, no in red uncorfimed.
No, Eragon, I am not in China.
Kind regards
acer2
Seems all OK.
Why does not work? Why I could not dowenload BH online update etc.?
Thanks el bandido I know must be green confirmed IP adress, not red unconfirmed
If I've understood well reading your file: are you in China?
If so, try manually changing your DNS, maybe some domain names are now blocked in China...
No Eragon I am in Europe.
Thanks all for your help.
Best regards
acer2
Best regards
acer2
I've noticed the CN country and this can be problematic only if you have wireless interferences but if you can download addons from Green Panel your box and your Internet connections are OK because feeds are localized in the same server.
The reason your box doesen't download them is unknown and is very silly ....
Thanks for answer, angelofksy1980.
I tried all I know, but I did not get confirmed adress.
Thanks again
regards
acer2
Thanks again
regards
acer2
I've re-read your debug file and I've detected a strange thing.
Your current wifi configuration
wlan0  IEEE 802.11bgn  ESSID:"TP-LINK_AE0CE2"
  Mode:Managed  Frequency:2.452 GHz  Access Point: F8:D1:11:AE:0C:E2
  Bit Rate=150 Mb/s  Tx-Power=20 dBm
  Retry  long limit:7  RTS thr:off  Fragment thr:off
  Encryption key:off
  Power Management:off
  Link Quality=46/70  Signal level=-64 dBm
  Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
  Tx excessive retries:0  Invalid misc:80  Missed beacon:0
but the driver detects an encrypted wifi network
  Cell 03 - Address: F8:D1:11:AE:0C:E2
  Channel:9
  Frequency:2.452 GHz (Channel 9)
  Quality=39/70  Signal level=-71 dBm
  Encryption key:on
  Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
  9 Mb/s; 12 Mb/s; 18 Mb/s
  Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
  Mode:Master
  Extra:tsf=00000022fbdf2d80
  Extra: Last beacon: 134ms ago
  IE: Unknown: 000E54502D4C494E4B5F414530434532
  IE: Unknown: 010882848B960C121824
  IE: Unknown: 030109
  IE: IEEE 802.11i/WPA2 Version 1
  Group Cipher : TKIP
  Pairwise Ciphers (2) : CCMP TKIP
  Authentication Suites (1) : PSK
  IE: WPA Version 1
  Group Cipher : TKIP
  IE: Unknown: 2A0100
  IE: Unknown: 32043048606C
  IE: Unknown: DD180050F2020101860003A4000027A4000042435E0062322F00
  IE: Unknown: DD1E00904C334E101BFFFF000000000000000000000000000000000000000000
  IE: Unknown: 2D1A4E101BFFFF000000000000000000000000000000000000000000
  IE: Unknown: DD1A00904C3409071B00000000000000000000000000000000000000
  IE: Unknown: 3D1609071B00000000000000000000000000000000000000
  IE: Unknown: DD0900037F01010000FF7F
  IE: Unknown: DD0A00037F04010006004000
  IE: Unknown: DD810050F204104A0001101044000102103B0001031047001000000000000010000000F8D111AE0CE21021000754502D4C494E4B10230009544C2D57523934314E10240003322E3010420003312E301054000800060050F204000110110019576972656C65737320526F7574657220544C2D57523934314E100800020086103C000101
I think you must reconfigure your box with correct informations like correct wifi encryption and the corresponding pre-shared key used.
Also use DHCP instread of static IP for the first setup because the DHCP will be invoked AFTER successfully association with wifi router
Thanks angelofski1980, I tried all of that but always got the same issues.
Thanks anyway.
Best regards
acer2
