Problem with USB and DVB-T Volar Black
ojerez
Hi,
I have BH 1.7.2 and USB Volar Black.I put the memory stick to put the Picons there,and it turns out that if I put the USB and USB Volar Black because the DVB-T is not recognized. Not in tuners. However,if I remove the USB, DVB-T is recognized and run...How can I fix this?
Regards
Hi,
Regards
Use an external powered USB hub my friend, you should fix.
Aver devices uses more electric power ...
So you can not put a USB stick and the Avermedia Volar Black at the same time?
You should try to connect your USB tuner or your USB pendrive to front port (for testing purposes only) and verify if all works correctly.
If all works, you need an USB hub jwith external power to use simultaneously your tuner and your pendrive.
