Problem with Usbtuner Compiled
Beor
Hi,
I am playing with an usb tdt and i get some problem.
It works i get image but verry unstable in zapping and some problem in HD channels.
The principal problem are FE_SET_FRONTEND failed or wrote 0 bytes in vtuner.
Someone get this problems and fix them?
PD: if i try with usbtuner of DE i don't have this problem ...
Thanks
Hi,
What is your USB device?
If your device is supported by BH images you can try to use that image and verify if you have the same problem.
Hi,
I have the same problem usb devices tested dib0700 and sms111x very unestable and many wrote 0 bytes.
But when i tryed the usbtuner of Dream Elite Team the problem gone and all work perfectly
I upload the usbtuner used for my test ...
Thanks
