Problem with video playback via LAN with OBH
telerec123
Good evening to all. :)
I switched from BH to OBH 4.3 to solve a problem i had with TivùSat.
I have a VU+Duo2 connected in LAN (10/100/1000) with a PC (Windows 7).
I was used, with BH, to reproduce the recordings (with windows media player) found on the HD of the VU+ directly from the PC, through the network connection (LAN).
Now, with OBH, the movie start but after a while they close, and if i try to go FFW the recording starts again from the beginning.
I noticed that this happens only if the recording is "big", if it is in the order of 500/700 mega it has no problems.
I try to watch the videos with VLC player, but the problem is the same.
It almost seems that can't cache, as if there were no band...
Another symptom is that movies that don't work don't give me the total time (a 0:0 appears at the end of the progres bar).
I tried to see them through OWIF streaming and everything works fine..
If i "physically" transfer the file to the PC, playback is normal without any problems.
It is not an important problem, so i look at them through OWIF, but i would be curious to understand where the problem is... :chair:
Thanks to those who will give me some ideas... ;)
Ciao!
