problem with vu+ manuals
iman_miri
hi i have solo reciver and in my apartmant use center dish for 20 home..
and recive 5 satellite{HOtbird.yahsat.badr.turksat.intelsat}
and i cant config my reciver
please help me
in manual no any Explanation... for advance config.... please help me... and full explane to me... thank u
In your user manual, page 22 is written, how to configure 4 DiSEqC sat (in case you have 1 Sat wall plug). Your house administrator should tell you, which Sat on what port is (example: portA Hotbird, portB Turksat, portC....).
thank u..... but i can config 4 satellie ... but my swich is 8 in put an 20 out put...and in simple mod only can config 4 swich
for 8 input or than what am i dooing..
please explain advance mode i think advance mode can do that but not any explain in manual.. for advance
if my swich is 4 input ican config
but my swich is 8 or 16 input{lnb} and 20 or mor than out put{reciver}
and in simple mode nut full config
and only 1 or 2 satellite can be config this mean other satellite not any signal
i answer this in persian and english.
iman aziz
moghei ke miri too tanzimaye lnb, be jaye simple gozine ro rooye advance bezar. oonja mitooni mahvare haro entekhab koni va ziresh shomare lnb ro moshakhas koni.
tanzimesh rahate. ta 32 ta lnb itooni tanzim koni.
dear iman.
when you are in tuner config page, you must choose advanced mode beside simple mode, with this option you can choose your satellite and set the number of lnb under it.
it is very easy to config. you can set 32 lnb in this option.
with regard
roozbehk
Hello iman. I do appreciate your posts and your skill on VU+. I have a VU+ Uno and I am learning about it. Is the owners manual on the reciever or on the BH image. I am still on BH 2.0.0 and will upgrade soon going to my technician. But I do wish to know more about it. I thank you for your contribution and reply. Thanks.
it seems your english is good. so you can find instruction in file that attached to this post in english language.
its tutorial for dreambox 800. but you can use it to config your box.
what do you exactly want to learn about bh?
and for upgrade you dont need to go to any technician, just update with bh online update. but its better to wait until 2.0.3 release and then update your box. it will be release soon.
Thanks for your reply. I think I can't upgrade on line with BH 2.0.0 I read that I can do it on pen drive but then I will loose my channel list and lines. I will wait for 2.0.3 as you say and then do the upgrade. I am happy with mu vuuno and BH image. Good picture :) Thank you again.
you can used chanell list...to update ur chanell list.... by dreamboxEDIT and edit an install new chaneel list on you box
and you can after config and setting on your box use back up and full back up...then every time u update your box by new image and load your back up evry setting you do is come back
