Problem with Wireless Lan Adapter [-NODRIVER-]
claude67
Hi do not Blackhole Image support Wireless lan standard N600? I have a usb Wireless lan adapter from Netgear WNDA3100 N600 it supports both 5Ghz and 2.4Ghz. With my old grey Netgear 2.4Ghz everything Works fine but its only 54 mbit in best case so no HD TV over my home lan :( but With the New adapter nothing Works so i Guess there is no drivers for it? or is there a way to get this driver?
Thanks Claude
Thanks Claude
If you have v1 version of the adapter you can use it with Vu+ boxes but if you have the v2 there is nothing to do. A driver is not avaiable for linux platform (PC, boxes, etc).
I can only confirm :(.
PS: TP-Link WDN-3200 is working for me on 5 GHz, but only on unencrypted WLAN.
